MAF Question
stevemainian
Virginia Beach, VA
If I were to disconnect the connector to the MAF while the engine was running, what should happen if the MAF was working properly. If it were working properly, wouldnt the rpms change?
Cocoa,Florida
my experiance is that somtimes it will run fine,sometimes it will sputter but to anwser your question your car will not run properly without the maf it could cause you to run too rich or too lean bes bet is to keep connected!!!,whay do you wanna disconnect it ???
