LPM tuning now at SHO Source
SHO1
Coke Is It!
The State Of Hockey
Are ATX & MTX LPM's actually a different part or are they the same part and can be tuned for either?
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
The benifit of the Tweecer is that you can do the tuning. With the LPM you need specialized software and equipment. We would be only good for basic tuning. Beyond that you would need to do dyno tuning on the spot.
turbo79
Saint Helens, Oregon
Basic Questions
Matt, I'm sort of starting from square one on this subject, but I need a little feedback on both choosing a MAF to use, and identifying which power module I have.
The car is a '92. I have both a 73mm C&L MAF and an 80mm MAF Lincoln MAF.
About the 73mm C&L; I had one installed, took it off because of erratic part-throttle issues, that didn't change when I removed the C&L and put the OEM MAF back on, but when I removed the Accel coil pack, and put the OEM coil pack back on the erratic part throttle issues (and even a hesitation/skip when accelerating) went away.
So the jury is still out for me on the C&L MAF.
But I would like to find out if I have an LPM that SHO Source can tune. When I got the 80mm MAF it came with an aftermarket LPM, that is supposed to plug into the existing computer that above the glove box.
This module can be switched between three "tunes," and it allows the 80mm MAF to be used, but I don't know if that same 'module' would allow the two mods I want: lowering the coolant temp at which the fan comes on, and raising the rpms at which the secondaries kick in to 4,500.
If the computer in my car now can be programmed by SHOSource for fan kick-in temp, raising the secondary cut-in rpms, and using the 80mm MAF, then I'll forego the module I got and use what I have, but what do I look for to determine that? Do you need a pic or is there a quick way to determine which computer is in the car now (it's the OEM one that was installed when new).
Don't know much yet about all this LPM stuff, but I'd like to make these mods.
LOUDSHO92
Sponsoring Vendor
The traditional LPM's do not have a 3-way switch so I would need a picture of what you have.
turbo79
Will Send Pic
Matt, I'll send you a pic of what I have. Can you (or anyone else) tell me, what does "LPM" stand for? I'm presuming that it's some kind of interface for the Ford ECM that allows it to be tuned (is that even the right abbrev. for the computer that runs everything besides the antilock brakes?)
Also, SHOForum folks: Didn't there used to be a post or thread somewhere here that lists a lot of the abbreviations that are commonly used when discussing SHOs and Fords in general?
Many thanks!
Tom Finlay
LOUDSHO92
Sponsoring Vendor
You have a Tweecer you can do the tuning on your own.
LPM stands for Lifetime Programmable Module. It is a SHOShop name.
kwforddude
Ontario
Hi, an old thread, where is the MAF located on the Mark Viii. What should a used one be worth?
Satchmoz
