RickieFrat:
AutoSHO:
You'd be surprised... when we went to bigger tires on our Dodge truck (all 4, same size) it made the ABS much less likely to engage (Rear wheel ABS only). We aren't sure why, though... Doesn't make sense. But, I'm just pointing out that it can happen.
When you place bigger tires on something that has a computer hooked up to it for a small size tire, it makes the computer think the tire is doing less work. Think of this, on a stock tire that we'll say takes 100' to stop from 65mph / will take longer on a bigger size tire due to the roll out lenght. Thus making the ABS think that the tire is not in any danger so the ABS will not react in time unless the tire is locked up causing damage to the ABS system itself. pcorn
