Okay the problem is still there. But not only on low tank. I notice it mostly when i drive to work and the car sits in the sun and i try to start it for lunch break (about 4 hours later). I am not getting fuel. The pump and all tank internals are new, as well as the fuel filter. There is no pressure at the rail. It cranks about an excessive 10 secs. Then the gauge shoots up and the car starts perfect. To me it seems that the fuel pressure is bleeding off and its like the whole fuel line drains back into the tank. So the time im waiting is for the fuel to be pumped from the tank through the line to the injectors.
Where does the fuel go. Isnt there a check in line to presserve the fuel in the lines. I beleive its in the tank right about the pump correct.
I dont think the injector is leaking it cuz if there was that much fuel in the cylindar it would smoke on start up and it doesnt.
Any thoughts?
