drdave
I have an elusive coolant leak (imagine that). It slowly leaks when the car is cold, which indicates to me that the system does not have to be under pressure for it to leak. The leak is on the passenger side and I assume close to the block, probably between the block and the firewall. I notice it dripping off the cat on the passenger side, the part of the cat closest to the firewall.
It seems to pretty well aft of the water pump. It is not towards the top of the motor. Are there fairly easily accessible coolant hoses in the location that I describe?
