digsj7
Digsj7
Here's what I got guys. It's a 95 ATX. The engine light comes on after I drive it about ten minutes. When I shut the car off, the engine light doesnt come back until I drive the car for another ten minutes. I went to SHOpheonixproject.com and followed the instructions to run a scan with the jumper wire (paperclip). Well, when I shut the car off, plug in the jumper, and go turn the key on..the engine light does not blink. So, I drove around for a while, the engine light came on, and I left the car running and tried plugging in the jumper wire and still no blink. Well, yesterday I was sitting in a drive thru (of all places) and the oil light was dimming on and off. The car started to idle kinda rough and the oil light kept getting brighter. After about ten seconds of that, the car died. I turned it over several times and it wanted to start...but wouldnt. I pushed it out of the drive thru, and turned it over about ten more times. Finally it started and I floored it ******* the rev limiter for a couple of seconds. Then it ran and idled ok. I drove it home and to work this morning (30 miles) and it seems to run ok again. When I am sitting somewhere for more than 30 seconds in Drive it starts to idle a little rough. If I have the car in N or P for 30 seconds, it idles ok. Every now and then the mass air has a humming sound to it (almost like a cold air intake). What would cause the oil light to dim in and out and then the car dies, and would the humming of the mass air cause any of this? Any advice would be MUCH appreciated!!
