93rev2sev
As many know, I am "refurbishing" my 3.2 before I drop it in to my MTX. I am replacing all the seals, and cleaning the block and heads the best I can without disassembing the long block (which is in great shape internally)
I will also be swapping in some new rod bearings.
I thought about doing the rod bearings first and getting the bottom end sealed up with new gaskets for the mains and oil pump to block surface.
Now, I am leaning towards waiting to swap the bearings until after the engine is installed. The logic behind this is...try as I might, it will be impossible to keep the engine completely dirt and dust free inside. The first startup could provide the potential for scratched bearings.
I might as well run the engine a bit with the old bearings and then change the oil and filter a couple of times before swapping bearings. I want to give the new bearings a nice clean engine.
Does this make sence?
