leaky tranny seal fix?
DavidT
TN
I am in the process of installing a rod shifter :thumb:
I was reminded of a tranny fluid leak. It is coming from the shaft with the rubber boot/ clevis bolt which connects to the shifter. Can I replace THAT seal w/out disassembling the transmission?
If so, any advice?
revhardSHO
Seattle, WA
If so, any advice?
yes it can be replaced externally. Autozone carries the part, I believe it is the "input shift shaft seal", or something to that effect. You'll be able to identify it quite easily, its just a round little thing. You may have to lightly tap with a hammer to get it seated correctly, just be careful not to damage it.
BTW- Did you figure out why it was running poorly?
DavidT
TN
yes, I was missing an idler pulley on the blower bracket. Installed the pulley with a new gatorback and now I am good to go :thumb:
Thanks for the info.
What about the rubber boot... it feels like it is connected to the seal...???
Will I lose lots of tranny fluid when I remove it? (remove it by starting a screw into the seal and pulling on it?)
clintonk
Apex, NC, USA
The seal isn't flush with the tranny case; the accordion boot just slips over a lip that is part of the seal. Get the replacement and you'll understand. I wouldn't expect fluid to come pouring out when you remove it, but please let us know how it goes. I replaced mine last winter, and the new seal is apparently leaking.
Clinton Knight
'90 White 197K
'95 Green 60K
revhardSHO
Seattle, WA
The rubber boot should just pull off. You shouldnt lose any fluid, at least I didnt, it seems like it should just pour out once the seal is gone, but it didnt. I forget how I removed the seal now but I didnt use a screw, I believe I used a flat head screwdriver and just pried it out (but be careful). It should be pretty self explanitory when your under there.
DavidT
TN
I was wondering...
I went to a couple stores:
looking under input shift shaft seal, they wanted to know if it was the Mazda tranny or the mtxIII... they said it makes a difference :shrug:
Bank of SHO
Vegas
I used an open needle-nose plyer around/behind the ****** to pry it out. It came out with virtually no effort. As said earlier, you will understand when you see the new part.
Good luck.
DavidT
TN
got the part.
Thanks!
I can't get it to fully seat though! In the process I AM butchering it :squint:
WHats the deal?
I am using a piece of pvc pipe that fits over the tranny shifter and rests on the seal... tapping it with a hammer. It will let one side seat (cockeyed), but I can't get it to seat as a whole.
Any suggestions?
yamahaSHO
E85 whore
Arkansas
Same thing happened with my first seal.... Use a common screwdriver and hammer and tap evenly until seated.
masho95
got Zex?
Chicopee, MA
I believe that's how I also installed mine. Or you could try putting a cap on the pipe and hitting it square in the center. Or put a piece of wood over the end of it and hit it in the center.
It's much easier to replace with the transmission out too... :D
DavidT
TN
thanks everyone.
I finally BEAT it in with a flathead screwdriver. No wonder they CAN be prone to leak, as someone said earlier... you have to butcher it to get it in! :smash:
