ycode90
^^Thats what I did....doing. Untill j/y 3.2L cost more than 500$ no need for purty forged pistons.
Slick. I'm curious, who's accelerometer did you use? My company has, at one time or another evaluated or characterized many of the single and multiple-axis accelerometers on the market. We typically only see them in wafer form, not the finished, packaged product. We're starting to look at MEMS gyros now, stuff with mechanical resonant Q's at 50,000 to 100,000, it's a real challenge to measure this stuff.Off topic, anyone here shoot pool?
gmorrell: You might get a smile out of my pool gizmo:
http://jandssafeguard.com/PoolGizmo/Stroke-Alyzer.html
.... The OEM sensor/EEC in a high boost situation sometimes is too slow to respond causing catastrophic results.
If the SHO pcm is programmed like the other Ford pcm's that I have studied and boosted, then part of the challenge is that the oem knock sensor is limited to pulling out 10* of timing when it detects knock. In potentially catastrophic situations, 10* of timing retard may not be enough, allowing the engine to melt down even though the knock sensor is 'hearing' knock.
Part of the tuner's challenge is that the engines typically produce maximum torque when there is slight detonation. Controlling that in the real world is very difficult, hence vehicles are typically tuned to stay away from any detonation.
For those of you who are doing tuning, and who are interested in fuel economy, if you tune the low-load part-throttle portion of the engine map for slight detonation, you will increase torque and reduce fuel consumption with no risk to the engine since a little knock at low-load doesn't produce high enough bearing loads to cause damage. Just be sure that by the time you get to 50-60% load you have the timing pulled back enough to eliminate the detonation.
Louis Ott "Louie928" has one on an 11.4:1 NA 928.
He posted a dyno experiment on the EFI University forum (efi101). google "louie928 vampire".
See his long post on page three of that thread. Nothing earth shattering, but it allows him to run low octane fuel if he has to, without retuning or sacrificing much power.
Concerning a "bad cylinder". Have any of you installed a colder plug in just one cylinder? I know a tuner that says he installs a three heat range colder plug in #5 on a 5.4L Ford. He said my Lightning video was confirmation.
Your rudeness is impressive.
In case you didn't notice, I raised the white flag when I posted my pool stuff.
I understand every one here is happy with the stock system. I'm just trying to demonstrate my design is not crap, as you call it. Plus, isn't it fun reading about other ways to do things?
I'm very proud of what I have accomplished on my own, with limited resources, perseverance, and God given talent. Yes, I said it.
I started working with knock sensors in 1983 while a tech at Hughes Aircraft, then introduced individual cylinder knock control to the after market in 1991.
To date, there are no other after market ignition boxes that have it. Even MoTeC and Autronic didn't have it until last year. MoTeC USA offered to buy my code after we demonstrated the system to them in '92.
I recently pm'd a GM knock sensor engineer on the C4 Corvette forum, and he wrote back "I enjoyed your letter, and I'm very impressed with your work."
His profile page:
http://forums.corvetteforum.com/members/64456-69427.html
