T.O_SHO
Power Hungry
So we just got the car back together after swapping out both LCA's because my ball joints were bad. Now, when driving the car the wheel does not want to return to center as easily as it did before the LCA change. If the wheel is at full lock and you let go it remains at full lock until you have to persuade it to go straight. This did not happen before changing ball joints. LCA's are solid, there's no visible contact between components and the rack is smooth as butter in the air, even when grabbing a tire and turning manually.
My tie rod ends need to be replaced as there is movement in the 3 and 9 locations, I am aware of this.
Does anybody have any ideas? As I mentioned the steering was smooth a butter and returned to center perfectly before the swap.
And yes, the LCA's are on the right sides.
