Keyless entryconversion
Sexymeatball
MA
Is it possible to put a factory keyless entry system from an SHO into an SHO that did not come equipped with one? I had heard at one point that all SHOs came equipped with the necessary connections and that all it took was a module swap from an SHO. Is this true? Thanks for your help.
/Jeremy
JTSHO
NO SHO
winston-salem,nc
well after inspection of 2 93 atx's last weekend, one with door code and one without it seems the harness connections are not there in the trunk. someone correct me if im wrong but i wanted to do the same thing and theres no connectors for the module but if you have the key code entry it might be different.
SHO Continental
Moderator
Northridge, Cali
last time I checked, the harnesses are different between no keyless, keyless, and remote keyless; aswell as, of course,the controllers in the trunk. If you have no keyless and you wish to go to keyless, I'd think you'd need a keypad? If you want remote keyless, the wiring can probably be traced somewhere to a plug and then put in. (I once tried tracing the wires on my remote keyless from the trunk but stopped under the driver's seat)
if you find anything let me know! :corn:
