keyless entry
Biggs
Michigan
Did the code change as described in the Sticky,it worked however when its locked and you pull up on the handle the pad doesnt light up as it previously did,until you touch the keypad,took the battery out for 20 mins(had to be cleaned anyways)and it still does the same thing.Any ideas?
NORMAN
FL
Why don't you reset it back to the original code to see if it will work again?
