Remote Key FOB Issues
Jake0811
Macomb MI
Been having an issue where my key fob will go haywire and lock the car without touching the buttons. I replaced the battery for some assurance in case that was what it was. Is it the touch pad or something internal? 2015 SHO. My smart key access works flawless. It's just the remote causing me grief. Any ideas???
kryptto
South East, Florida
Been having an issue where my key fob will go haywire and lock the car without touching the buttons. I replaced the battery for some assurance in case that was what it was. Is it the touch pad or something internal? 2015 SHO My smart key access works flawless. It's just the remote causing me grief. Any ideas???
Me re than likely something cracked and shorting in the pad.
Bronco2fan
Texas
There's little rubber like disc that separate the connectors in the fob. Mine started not unlocking with the fob. Took it apart and saw it had moved. Little dab of super glue and put it back. It's been fine since .
Jake0811
Macomb MI
I'll try to see if that's my issue! Thanks for the insight!
hosbaldosho
