FastAndFurious
I've searched but couldn't find the answer.
I thought water got in where the keyless entry pad is. I pulled door panel trim out and then tried to get to the back of keyless entry pad but couldn't get there. I hooked battery back up to roll down the window glass and then the keyless entry light came up! but then it went off about 3 seconds later. I unhooked battery and hooked it back again to see if it's doing it. Yeah, it lights up for about 3 seconds everytime I hook the battery up. I'm wondering actually the keyless entry is working but like ground wire or something is loose. What do you guys think?
If I still have to get the pad out, do I need to remove window glass? I basically removed just door panel trim.
