keyless entry pad? asap please
10ktgold
columbus ohio
i found a sho at the junkyard with the door lock pad , will it be hard to hook it up? what will i need , i plan on buying the door , its the same color as mine , how do i figure the or recode the code to open the door? i read somewhere that theres a thing in the trunk that i will need also , so whatsup , what do i all need to make this happen
jelloslug
Digital
Greenville, SC
You will need the keypad (and a way to mount it) the RKE box from the trunk all the wiring that runs from the door to the trund and maybe some other stuff too. I'll have to check a wiring diagram. Not impossible, but difficult if you dont have the doner car right there to go back and pull parts off of when you realise that you need soom other odd little module or bit of wiring.
heath94
Raleigh, NC
How does the pad attatch to the door, Two buttons on mine are bad, going to do the swap, but wander what if any tools I need to carry to the junk yard to pull the donor. I don't want to experiment on my SHO!! :D
munkee
Too busy...
Missoula, MT
To remove the pad, first remove the door panel. Then you will see the pad up at the top of the door. There is a spring clip holding it on. Just use a pair of pliers to pull it out and the pad will slide out. All you should need is a philips head screwdriver and a pair of pliers.
jelloslug
Digital
Greenville, SC
Be VERY carful when you remove the clip. If it pops off fast you can slam you hand/arm into a sharp sheet metal edge and get a nice gash.
Detenator
Rockland, NY
To figure out the code, you will need to look into the trunk. THere is a small black box on the left side of the trunk with a sticker on it. Those numbers on the sticker are the combonation for the keypad. If that sticker happens to be missing, you can open up tht unit to figure out the code. I think shotime.com has detailed instructions on how to do that, and also how to change that code.
10ktgold
columbus ohio
thank you very much , i plan on taking the whole door , so all i need is the wiring , or i'll cut it from the pad , and by the box but keep it long enough to re wire it ,
<small>[ April 16, 2003, 07:59 AM: Message edited by: 10ktgold ]</small>
10ktgold
columbus ohio
well i got it , is there supposed to be a 5 digit code? cuz it says on the box on a little white tab ,xxxxx (but numbers :) ) ,where can i get a wire diagram?
