keyless entry code???
Rio
West Bloomfield, Michigan
hey can u guys help me w/ my keyless entry code???
i've heard that its in the trunk, and i found a sticker on a black box in the trunk that was ripped. All i could make out was rem--- and I'm guessing two numbers of the 5 for the keyless code entry. 59---. Is there anywhere else I can find the keyless entry code???
I have a 1993 ATX :confused:
Not sure where else it would be. How about rifling through the trunk some more. Maybe the sticker fell off the trunk lid and worked its way into a crevice or in the spare tire area. The sticker is very small.
Andrew Tilson
Chubbuck ID
you could also dismantle the module and find out the code that way :)
<small>[ August 17, 2002, 03:01 PM: Message edited by: Andrew Tilson ]</small>
GreenBird
Barre, Vermont
we are talking about the buttons you push that are just above the door handle?
My 90 and my moms 94 both have a sticker in the glovebox.
naval-avi8or
Chesapeake, VA
Just checked my 94 and shonuff there is a small sticker 3/8" by 1" with the 5 digit code. It is white with black numbers on the passengers side vertical portion (to the right of the license plate but on the inside).
Porod
Green Bay, WI 54301
You may be able to get it from Ford, if you go and talk to your local Ford dealer. I'm not sure how much bother that would be, or even if they could help, but it wouldn't hurt any to ask.
projectSHO89
SHOless In St L
