FOMOCOTOSHO
I eat Rice.
Ok I'm not sure what's going on here. I have a 1995 ATX that is relatively stock that I keep frying the alternators. I bought the car just over a year ago and the alternator went out shortly after (it was still the original at that time I believe around 130k) It didn't seem anything out of the ordinary and I wasn't doing any kind of high-revving or anything. I installed a Ford Motorcraft Reman unit.
So this past fall I installed my SCT chip that removed the rev limiter (which I didn't realize when I was trying to see where the computer would force the transmission to shift from starting in 1st gear being selected & going WOT) Woops! I thought the nanny would have kicked in but it didn't, so I fried the relatively new alternator @ about 8000RPM. So I warrantied out with another Motorcraft Reman alternator this fall.
Since that time I have installed the SHO Source UDP crank pulley. The SCT chip does increase my shift point, but it only takes it to about 7200RPM in the 1-2 WOT shift.. the other shifts don't ever crack 6800RPM when u let the computer shift.
So now yesterday while leaving home work I was screwing around with some annoying steriod freaks on their crotch rockets and I was racing them a bit from a few different stop lights (I knew I didn't have a prayer but it was fun) But while slowing down from the second WOT run from light to light, I saw a large billow of smoke or something come out from around my RF passenger wheel/trunk area. I first thought it was my brakes because I just put brand new pads & rotors on and hadn't really broken them in hard yet. However about 3 blocks later my EATC started blinking out on my and my battery light would come on intermittently. F*CK!! I had to limp home as is because it was too late to do anything about it last night so I turned off my radio and all my lights, etc. I got it back to the shop today (I work at an auto repair shop and have access to it after hours) and now only did I fry the alternator, but the battery seems to have overheated or something & it leaked some battery acid all over the battery holder tray. So I not only had to replace the alternator but the battery too.
Any clue as to what is causing this last one? I know the first two times can be explained for the most part, but I'm baffled at this last time, especially the battery.
Any clues?
Thanks for anyone's help
Any clues?
