jbl sub location
1shotime1
PA
I'm almost 100% sure that the stock jbl sub was removed b4 i received the car becasuse i just can't find it!!! Unless it is in some hideaway place taht i can't see!!!! Where is it located??
Dan smith
95 red atx
jcostantino
Coral Springs, FL
Just like Cenc said, it's hanging between the two rear speakers. If you had it there should be 4 threaded studs still there. Some SHO's didn't come with it (mine didn't) and the studs wouldn't be there.
Jeff
1shotime1
PA
if i was to but one from ebay or something would it just bolt right up??? Are there wires already prewired that i just have to connect or will i have to wire.....If it's not just bolt in, i'll just go w/ aftermarket!!!!
Thanks-
Dan smith
1shotime1
PA
I thoguth all sho's had the jbl sub, was this an additional option???
naval-avi8or
Chesapeake, VA
If your car wasn't equiped with it than you will not have the correct amp and wiring for the sub. Look in your trunk at the amp(s) and they should have JBL printed on them. The sub amp mounts in the center and the 4 channel amp is on the pass. side. As for the wiring the sud gets its audio input from the 4 channel amp from a small jummper wire and it recieves its power from a black box mounted just above or below the amp.
pbshow
Lake Elsinore, CA USA
If your SHO doesn't have the JBL Sub and amps, I have a complete setup that I can sell you. It includes everything you need (except the four mounting studs for the sub box) sub box with sub, two JBL amps mounted on the factory bracket and I'll throw in the four JBL speakers.
Paul
[email protected]
SHOMA
Springfield, MA
pbshow, that doesnt help him wire the whole system from front to back! I know a 93 atx I had didnt have the jbl system, and didnt have 1/2 of the wiring necessary!
pbshow
Really? My first SHO was a '92 that came through without the JBL System and I bought the whole rear setup from one of the SHOForum people, and it all bolted right up, except I had to add the four studs for the box. Everything worked fine.
jniemiec
Michigan City, IN
mines missing too... i have a 93 mtx... it looks like the sub was there but the original owners took it out, i can see where it was hooked up. theres even rings around the area where the screws were, but are not there anymore.....
Tommy's SHO
SHO Member #535
Montréal, Quebec - Canada
naval-avi8or:
Where do the yellow and red wires coming out of the sub amp. go to? Is red power and yellow ground?
naval-avi8or
Chesapeake, VA
They go to the Radio Reciever Suppression Choke Resistor, It is a small about 3X3X1.5" black box that mounts between the amps on the brace between the two cut outs the seat mounts against.
