Jacked Up Idle....
DigDeez
Chicago
The other day after cleaning out the clogged EGR valve through the throttle body with some Berrymans B-12 Chemtool, my idle speed got stuck at around 2K rpm. I was reving it by hand, let it go and the engine did not drop back down to normal idle speed. I also revved it from inside the car and the same thing happened.
P.S. One of the nostrils apart of the EGR valve was clogged; poked it out with a hanger; drove the car; CHECK ENGINE light still came on; next day and since, no light thumb However, when I did the 'suck test' of the line from the EGR valve the engine didn't drop in rev. Maybe I wasn't sucking from the right line? I no, I should run the codes, right?
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
You should have reset the idle after fooling with the EGR.
and yes, pull the codes... see what your car is trying to tell you wink
A high idle can also be a sign of a vacuum leak and after doing intake and EGR work, that is a possibility. Check those gaskets and vacuum hoses. You might also see a CHECK ENGINE light and a lean condition if the vacuum leak is severe enough.
DigDeez
Chicago
Gladly, the Check Engine light hasn't been on in a few days...the first time in months.
Will run codes and check those things out.
DigDeez
Chicago
PROPHET:
I'd say a vaccum leak,proabably a line for the seconderies,was with mine.
Now, with checking vacuum lines for leaks, is it simply a visual inspection. What all to look for and which line did you find to have the leak?
