The other day after cleaning out the clogged EGR valve through the throttle body with some Berrymans B-12 Chemtool, my idle speed got stuck at around 2K rpm. I was reving it by hand, let it go and the engine did not drop back down to normal idle speed. I also revved it from inside the car and the same thing happened.
P.S. One of the nostrils apart of the EGR valve was clogged; poked it out with a hanger; drove the car; CHECK ENGINE light still came on; next day and since, no light thumb However, when I did the 'suck test' of the line from the EGR valve the engine didn't drop in rev. Maybe I wasn't sucking from the right line? I no, I should run the codes, right?
