Is my IAC bad? (did I test it right?)
1993MTXSHO
Its a Taurus...
Jersey
Short story is, car wont Idle stalls, when i raise it or hold my foot on the gas it runs and drives fine. I ran a resistance test connecting the 2 prongs on the IAC and it came back 0, which I would think means the IAC is shorted. I also checked the connector and it is getting 11 volts or so. So is that how you test the IAC, by testing resistance across the 2 prongs?
SASHO91
Zoom Zoom
San Antonio,TX
You can simply pull the IAC, off the manifold and have someone turn the car to the ON position, you should see the IAC move. If you can't find anyone, or have no friends ( :biggrin: ), you can just take a 9v battery to the IAC and see if it moves.
1993MTXSHO
Its a Taurus...
Jersey
oh ok that works, ill do that tomorrow:cool:
RAYJAY
WHO ME ?
UNION DALE PA
smack it with a screwdriver (not hard) and see if it will idle..... Key on engine off, if that dont help try it while running
some how i see a 5lb sledge in action here .................:theyareontome:
Jeff
for real now did you clean out the nostrils on the intake really good if there blocked will cause you a problem also
1993MTXSHO
Its a Taurus...
Jersey
ok well I took it off and looked at it and it didn't move. so its bad, I didn't try hitting it but ill have to try that next time im home. Im back at school now so ill take a crack at it mid December or have my dad go out and try it:cool:
shoclown
shoclown
sacramento ca
when you took it off, did you give it ground? it might be a case ground..
also if someone has tried to adjust the idle incorrectly it might just be out of sinc.. also it works by pluging a vacuum leak if the passage is clogged up it wont work either.
1993MTXSHO
Its a Taurus...
Jersey
no I didnt ground anything what do you mean by that? how can i ground it? I also did clean the crap outta it with carb cleaner so its pretty clean inside.
tinkerkathleen
