GEN 3 SHO FAN
I deleted my IMRC 2 years ago on the advice on some here. I must say that there is praticaly no change on power loss at low rpm but power and sound are coming a little bit sooner than factory (3000 rather than 3400 factory).
However, I remarked that the heat is a little bit higher with this setup (more air metered, more fuel and then more heat...)
I'm wondering if a cooler thermostat (170 or 180) will be a good maintenance upgrade considering this. (?) I know, in a perfect world, the fans have to be reprogrammed to work correctly with. But it will give a chance to the engine.
Thanks for the advices,
