Intrax?
zblackbeast
SHOtarded
Omaha, NE
Only if you cut them. But you can either buy adjustable mounts from shosource.com or drill out the alignment tabs at the top of the strut tower to allow for proper adjustment.. unless you SLAM your sho you'll never really never run into alignment issues in the front. Now in the rear, any drop is going to be hard to align because your can't just get adjustable mounts, you'll want to get adjustable lower control arms.
jayro
Auburn, In
You can also use an air chisel/hammer with a flat wide blade. That is what I did.
