intermittent hard start/stalling
I'll sho u
saint john,nb,canada
If you drive my 94 mtx for a long time,then shut her off It may mot restart for a period of time.Sometimes it starts right up sometimes not.The car cranks like it has no fire.I can hear the fuel pump running,the tack moves while cranking.I checked the codes they are 211 and 157.I know the 211 code pertains to the crank sensor so I will replace that next weekend when I was planning to do a timing belt anyway.I thought that if the crank sensor was bad that the tack would not work?The car is also sluggish and will stall sometimes when comming to a stop with the clutch pushed in apon which it is real hard to start.Does anyone think that the cam sensor may be bad even though there was no code for it,or possibly the module or coil packs?
