SHOOFF508
Out of Retirement (again)
Installed a new upper plenum today, all painted and the like, after re attaching all the needed coolant and vaccum lines and making sure everything was tight, started the car, wouldnt start unless i applied the gas a bit, car runs fine but wont stay running unless im on it. somone suggested a vaccum leak, after rechecking all the bolts to the lower intake, and all the clamps for the rubber couplers, i sprayed the intake down with soapy water, and didnt find any leaks, hissing, or any signs of a leak. i have no trouble codes ether. a VERY slight adjustment to the idle set screw on the throttle (probably not the best reapir possible) seemed to clear it up with the car idling quietly around 750-900 RPMs aprox. Previously i had lean condition codes but replaced the Y pipe and 02's. no codes now.
