Intake question......
Nick's SHO
Norton, MA
Im planning on taking my intake apart. What should i look for when im takin this apart other than the bolts and screws? Are there any hose i need to unplug, sensors, etc.....Thanks
MYSHO1
PiCkLe DaNcE!
Wakefield Ma, e.p RI
IMO its easy on a sho, Just run your hands along the side and you will come across everything that need to be unplugged, If its cought take the time and see what its cought on dont just yank it out.
Ace
Manning Hater!!
Norfolk Mass.
the hardest parts is disconnecting the hoses underneath the throttle body area...a second set of hands would be helpful here....
Jonny Cash
Good boy
Hollywood, FL
Yea the coolant hoses are a *****, but once you do it a few times its like flipping a switch. ( you really dont need them )
Make sure to tourqe those bolts when you put it back together. :thumb:
greenbeanmtx
King Skidmark
Waco Tx
They pretty much covered everything. Make sure you take the metal arms that brace the intake on the front and rear off. When you go to re-install make sure you dont let the secondaries hoses get stuck between the intake and the manifold or you could tear them. Once you remove it once its a breeze from here on out. Those coolant lines are hard to get to but if youve got a good pair of needle nose pliars or long pliars its not too bad. The trick is getting the clamps off and getting the hose to come loose. Its not bad though.
