Insulating wire harness
pitbull
SHOmanyproblems
North Bay, Ontario
Ok so I have the intake off my motor and am looking at the wire harness on the rear valve cover. It's melting.
I was looking at header wrap on ebay, and was going to purchase some to protect it with, but then I noticed it said that it was made from fiberglass. Could I instead use some leftover fiberglass (the woven blanket style) used for body repairs instead, and achieve the same effect? What have you done to protect yours?
pitbull
SHOmanyproblems
North Bay, Ontario
unfortunately I wont get that in time before my car is reassembled.. I wonder if they would carry something similar at the local industrial/electrical supply store?
NebraskaSHO
Harumph!
Omaha
I used some hi temp aluminum tape. Basically aluminum foil with an adhesive backing. Works good, I need to re-wrap some parts up front.
NikonPhotos091
E1
Crash Tested
Chicago area
I don't think I like the aluminum thingy. If someone who isn't that sharp wraps that around already damaged insulation wires, couldn't that become a nice ground?
Mr Anonymous
Tire Wall
Yikes! Well I guess at least the aliens won't be able to communicate with your car with all that aluminum shielding! :nut:
Go to your local speed shop and get a foot of 3/4" to 1' fire sleeve and slit it lengthwise. Should cost about $18 or so.
