.:Installing Keyless Entry:.
Yoon
Anchorage, Alaska
Hello,
I was just wondering the easiest way to install a keyless entry to a 1990 SHO. More specifically, what is the easiest way to access the wires that are in the kick panel for the positive and negative wires. They are supposed to be Pink/Lt. Green and Pink/Yellow for the two wires... What is the easiest way to get to these, and also, will i need a separate relay?
Thank you very much
megaplay
Cincinnati OH
To get to the wires is fairly simple. Remove the trim piece on the driver side with the screw under the hood release and first screw on the kick trim piece. Pull back the carpet and a black plastic protector shield and you will see a bundle of wires. The two wires you are looking for, Pink/Lt. Green and Pink/Yellow, are in this bundle. For my alarm/remote entry need two, one for each, SPDT. Make sure the normally closed position has a terminal though. Most 12v relays with spade disconnects don't. Good luck with it.
