Inspecting bearings
Devin
3.Slow
Pacific Northwest
If the cap bearing is in good condition, is it necessary to inspect the rod bearing? If so, I am just inspecting the crank journal side?
AREA 91
PA SHO SHOP
Area 91
All the load from the combustion process is downward on the rod side of the bearing. This is more important than the cap side.
Devin
3.Slow
Pacific Northwest
Hmm, so it looks like the easiest way is to remove the spark plugs so the piston can move out of the way, and then I can move the rod to either side of the crank to get at the bearing. Then I guess I can pick the bearing out with a plastic tool.
AREA 91
PA SHO SHOP
Area 91
No need to remove the spark plug. You can use your fingers to remove and install the bearings.
Devin
3.Slow
Pacific Northwest
Ah, no valves are open. So I just have to turn it until it is on the intake stroke.
Devin
3.Slow
Pacific Northwest
Bearings (and journal) look fine. Once I reassemble I will see if the oil light continues to flash.
Bearings all Bearings close 1 Bearings close 2
Devin
3.Slow
Pacific Northwest
New bearings are installed. Took about a minute and a half of cranking (about ten a shot, and then a rest) for the oil light to turn off. Drove five miles and there were no issues, aside from a rattle that sounds like something I didn't tighten all the way.
I am now a little confused about why I had the oil light and what I swear were metal flakes in the oil. The bearings didn't look bad.
Off Road SHO
Moderator
Oil flakes may have come off of your oil pump housing. Get your oil analyzed two oil changes from now.
Tom
lingyuair
