IMRC
ricky
sharpsburg,nc
got code 1518; pulled engine cover; visual inspection of IMRC showed :confused: no broken or inoperating parts. Question: how much play should there be in cable at engine off? I've got enough so the cable end is quite loose. [end connected to butterfly controls]
E1
Crash Tested
Chicago area
ricky:
The cable should have some tension on it. The end should not dangle on the connection. Perhaps the INSIDE end of the cable is either frayed or stuck on a bit of debris which is preventing it from returning completely. I would suggest opening up the box and checking out the IMRC internals for any types of interference to the cable.
ricky
sharpsburg,nc
went to actron web site [scanner maker], got exact meaning of code p1518 [runner not closing, bank 1], took apart intake down to head, cleaned out carbon build up, now runs like a SHO. THANKS for your responces. pass along the actron web site, gives great descriptions of codes, best I have found anywhere
