J.L.Gordon
95 atx,no codes,run's then the idle drop's and it sounds like the intake is going wide open.driving the car run's like its starving for air or fuel.sitting at a light the car surges if your not ready it will drive you into the car in front of you.new=MAF,VSS,EGR,Plugs,wires,ats,all vac lines,icv,all egr support elec,new intake hose's,new gasket's,rod bearing,crank sensor,cam sensor,timing belt, surges and buck's and die's sometimes if I keep touching the gas pedal rapidly i can keep it going.This was happing before I did all of this.with the key on i can hear the fuel pump cycle.I'm going to change the fuel filter in the morning .
