igntion fuse keeps blowing
sho4life
midwest
i bought a sho that a guy had and he said he welded on the body and forgot to disconnect the battery. well he blew the cpu and replaced it but it still blows fuses . what could need replacing?
Off Road SHO
Moderator
I believe the coolant overflow resevoir has a sensor that tells you when the level is too low. When that sensor is bad, it will blow the little 10 amp fuse in the underhood fuse box.
Tom
SHOMON
95 MTX
MEDWAY MASS.
Tom
Tom is right. I would just unplug it. Is the car an automatic?
sho'noffmtx
Many SHO's
Delano,MN
ive had that coolant sensor go bad so its the best opion but did you look around the area where the welding was to make sure there are no melted wires?
sho4life
midwest
its a manaul and after looking up research on this problem, goin back to 2004 it seems that the sensor for coolent kept popping up. im goin to drive 3 hours to get this car, hopefully were all right about this, thanks guys
crystizel
