Ok, so in order... (All numbers are RPMs unless stated, and RPMs are always at idle unless stated)
Reved engine hard (5000s), went up a hill in gear, coasted down hill, Idle at 3000... turned car off, popped hood, started car again, shot up to over 2000 then leveled off at about 1200, got out with car still idling, opened throttle manually then released, idling at 3000, turned throttle to close till it hit the stop bolt, idle came back to 1200, tapped throttle body with hammer, erratic idle (didn't see numbers but changed rapidly), wiggling the throttle has a similar effect. Replaced IAC as it already needed to be replaced. Tapping no longer causes erratic behavior, everything else the same. Replaced TPS, idle is now more like 2500 and when the clutch is in it drops to about 1200 and waffles back and forth to about 1800, releasing clutch sends it back up to 2500, cleaned MAF, no change. Sprayed starting fluid at all vacuum lines I could find to see it there was a leak, nothing. Pulled codes, TPS out of range, realized I bought the wrong TPS (Matched OE numbers to replacement numbers), installed the correct TPS, no change.
Is there something I am missing? I will clear codes tomorrow by pulling the battery cable and driving for some time during the day, but I have no clue what else it could be unless I have a vacuum leak I cant find. Any input is greatly appreciated.
