Idler pullies
2 4shofast
Ogden Utah
I was wondering if the idler pulley bolts will clear the fender frame. I replaced the closest one to the radiator already but I barely got that bolt out and I am hoping the other two dont have as long of bolts. Any info would be awesome. Thanks :thumb:
stephen newberg
Ladysmith, BC, Canada
I did not have any problems with the bolt length when the idlers were replaced back a couple of years ago, but it was a warranty job and I did not watch them all the time. However I saw nothing during my trips back there every 15-20 minutes or so to indicate they had to shift the engine or anything else to get the bolts out.
pax, smn
naval-avi8or
Chesapeake, VA
2 said:
I got mine out a couple of days ago, but my V-8 is in a 94. If you want to measure the clearance between the bolt head and the fender, I can tell you if it can come out with out having to do any tricks on 96-99. I was told that it will come out by loosening the front motor mount to frame bolt and slightly raising the motor.
