idle drops
bensho92
when i drive my car and i suddenly press the clutch the rpms droop to 300rpms almost shuting the car off all the cluster lights flash for a sec, then rpms come back up to about 800rpms, i cleaned the idle thingie and the MAf and reseted the comp and still does the same thing.
bensho92
i took the negative cable off and hold the brake for couple of seconds to get all the power out and after 2 minutes put the cABLE back and drove the car.
jonysho
owasso Ok. U.S.
does your sho have underdrive pulleys. Mine does and i have the same problem occasionally. Mostly when it's cold outside.
I think with mine the engine is not able to rebound because of the pulleys. I 've got the 8lb flywheel idon't think that helps any either. Maybe we've got the same problem and can both get a solution to the problem
91 SHO underdrive pulleys, cold air, 80 maf, eibach springs w/ koni adjustables, pp y-pipe, dynomax catback system, ted roe superchip, IRT stage 2 clutch, 8lb flywheel, sub frame connectors, polybushings, alum. sub bushings, 17" team dynamics racing wheels, kdw y-rated tires. Cowl hood, police grill,upgraded antisway bar, Baer 13" brakes,
bensho92
my car has a cat back exhaust k&n and quife and it doesnt have an ac compressor. i can hear the power steering pump make noise and i tought it might be it thats locking up or one of the belt tensioner bearings, as soon i get some money il replace the ps pump and se if it helps.
You didn't reset the idle program with that method. You need to disconnect the battery, turn on the headlight switch and wait a good 15 minutes. After turning off the headlight switch and reconnecting the battery, start the engine. Allow the revs to come down a little over the first 10-15 seconds after starting. Now, within the first 70 seconds since the key was turned, add all of the accessory loads that the engine will see at idle: climate control to AUTO, headlights to ON, steering wheel turned side to side and brakes applied. Do all this within that first 70 seconds to teach the EEC the range of loads the IAC valve will have to compensate for. By not adding any loads, you didn't give the EEC a chance to see the range of travel the IAC valve will have to cover to bear the load from all the accessories. Send your engine back to school.
Scott
