idle and drivability problems
zerg1024
NJ
my sho is haveing a whole bunch of problems well i should say just one big one. my car is studdering like it is miss firing but i replace everything that could cause that and now it is still doing it. what could it be? when i rev it, it sounds like 2 or 3 cylinders arent firing and when i start to go from a stop it studders then goes back to normal operation, also under acceleration it does that. could it be the timing.
Camarok
Awesome SHO Member!!
Milwaukee, Wisconsin
ok you said you replaced everything... what is everything? did you do spark plugs and wires? if so ( i did this ) make sure you put the plug wires in the right way on the coil pack?
Engine
123
456
Coilpack
51
62
43
that's how it should look. I had the same problem... I thought I had too much carb cleaner in my intake from the 60k... but it didn't stop so i rechecked and that was it
Good luck
zerg1024
NJ
yes i replaced the spark plugs and wires. i also replaced the CID, IAC, TPS, DIS module and Coil pack. i havent gotten a chance to run the codes i am going to have to do that on friday since that is my only day off so. i really dont know what it could be with my car. do u think it could be the timing is off?
Blank-Disk
New Mexico
i'm having this exact problem right now. Even when the problem is occuring the comptuer doens't throw any codes. Also, a Cyl balance test won't work because it advances the timing too much for the problem to occur. First, try HEAVY duty injector cleaner, that helped mine a lot, but didn't stopt eh shaking. i too am looking into a timing belt tensioner issue.
zerg1024
NJ
well could it be the timing is off or could it be the computer. this happens when i am starting to go from a stop and continues then when i shift gears it goes away until i give it more gas. i dont know what to do i am about to give up on it if it is something internal on the engine cause i dont have the time nor money to fix it. it is my only means of transportation so.
zerg1024
NJ
no no oil in the plug wells nothing i really dont know what is wrong.
Make sure the plug powering the coil pack is secure and that the rubber seal is not interfering with the fit of the plug.
Mr Anonymous
Tire Wall
And grounds, check the grounds. This is something that's often overlooked, yet can cause all sorts of problems.
zerg1024
NJ
i did all that and still nothing it sounds like it might be fuel system stuff like a previous post was made on the forum.so i will have to check that too.
