I think i damaged something
DARTHSHO
South Florida
FFF28B55 C761 4726 857C F47512FEF539 I figured while we are not busy for corona I would try and tackle the pesky back spark plug again. While I was trying to break it free and after the socket got stuck I realized I must have leaned on the tube from the air Intake and dented it. Is there a way to get the dent out or is it just time to fork the money over for those separate intakes
ridered74
You could try disconnecting it and pushing it out from the inside.
ridered74
Got a small block of wood or something similar that is solid? Could try putting that in and then using the screwdriver as a lever to push up on it.
wraitherx
va
I’ve seen where people heat the area up with a blow dryer and then used canned air, upside down to get the liquid out, and then dents pop out of metal body panels and plastic bumpers. Maybe give that a try? At the very least it’ll allow you to heat the area up a little bit to make it malleable to push something in it and remove the dent. Just not too hot where it’ll deform they plastic.
Kevin81
USA
Heat it up. Put a wet wash cloth on it, and hit it with a hair dryer at high heat. This will get it close to 200 degrees. Maybe, 180, 190. Plastic becomes malleable at that temp.
SuperPete
PA
I got same thing on my car, I was looking at it and thinking to myself, what was ford thinking putting that thing on the pipe, LOL
DARTHSHO
South Florida
O ok cuz the car just seems a little slower since I noticed it and I could have sworn it was not as indented as before
DARTHSHO
South Florida
O ok cuz the after going for the back plug I realized I might have leaned on it lol but not the issue
If you leaned on it, is it possible you created a small vacuum leak where the tubes clamp together or a small crack in the plastic? Just spitballing from that area. Or maybe there is a faulty plug or coil back there.
b4black
IL
yes lower fuel and car is slower. im seeing A/F at 14.08 normally it runs pretty close to stoich or a little lean
14.08 is stoich for E10. That's where the factory tune is set.
stripSHO
Idiot Savant
Detroit
Lmao obviously we're all doing the same thing with our abundant free time. I too noticed this on my car for the first time a couple days ago!
B-Aero
