I Need Heeeeeeeeeeelp
FeZ_MsTr
hayward, ca
hey guys... i need some help...
i have a 93 SHO.....
during the last few days,,, it wouldn't start right... it would HESITATE to start .. i think it's the starter.. but now..it wouldn't start and i dunno what the problem is.. i think it's the starter.. i'm not good with cars so can u guys gimme some advice ? plz :confused:
Dr. Tweak
Mad Scientist
Northern Vermont
More details please:
Does the engine crank? If no, does it click? Can you hear the fuel pump priming when you turn the car to "On"? If it doesn't turn over, can you jumpstart it?
FeZ_MsTr
hayward, ca
ok... it doesn't crank... clicks but u can bearly hear it if u are very close to the engine with the hood on... i don't know if the fuel pump primers.... maybe it's the sound u hear when u put the key into on ..not start... it does that... and no ucan't jumpstart it
Dr. Tweak
Mad Scientist
Northern Vermont
It's like a hum when you turn the key on, but that's not the problem, since the car isn't cranking.
Have someone try to start the car while you smack the starter with a hammer. Also check your wire connections at the starter. When you hit it with a hammer it may start. Your problem is either a bad starter (if you hear the click then the solonoid is working) or a bad connection going to the starter.
FeZ_MsTr
hayward, ca
one thing is that i dunno where the ******* starter is!!
my friend said that it's under the car crammed somewhere... if possible.. can u like inclue a rough sketch on paint or something to show where it is?
thnx
Dr. Tweak
Mad Scientist
Northern Vermont
It's right below the oil filter at the very front of the engine (front as in towards the front of the car). You can't miss it.
It's barely visible at the very bottom of this pic"
FeZ_MsTr
hayward, ca
is the one from the pic from a SHO? is it visible and accessable if you open the hood esily? and if not? how do i get to it? i am not a mechanic srry! lol
anyways... what does it look like? and what type of wires r connected to it?
Dr. Tweak
Mad Scientist
Northern Vermont
You can't really see it from the top. Slide under the front of the car, look at the oil filter that's right above your head. Look under the oil filter, that round cylinder type thing with some wires going to it is the starter.
*edit* Yes that pic is from a '92 SHO
FeZ_MsTr
hayward, ca
oh kool... thanx i'll take a loot at it 2morrow..
oh by the way... do you know how much theu go for? and how hard is it to replace one by yourself?
Dr. Tweak
Mad Scientist
Northern Vermont
Let me check...
I don't think they're too hard to replace, do a search and you'll find plenty of threads on the subject.
*edit* From Autozone.com, $109 for a cheap one and $139 for a good one, plus core charge.
Bizzy
First things first. Check the voltage on your battery before you do anything else. If the charge is low it will cause the starter solenoid to make the clicking noise. Don't buy a starter until you're sure that the starter is the problem.
Dr. Tweak
Mad Scientist
Northern Vermont
Just curious, since he said "no u can't jumpstart it", wouldn't that rule out the battery? Since it doesn't turn over even with a jumpstart? That's always how I've understood it... :shrug:
Mr Anonymous
Tire Wall
Not necessarily. A really bad battery can cause a no-start even with a jump.
Try disconnecting the battery and jumping directly to the cables to see if that makes a difference.
Blank-Disk
New Mexico
A starter is not difficult, two bolts hold it on, and then the wire bolts. There's little room to work, btu with a socket wrench and a lot of patience, it's about a 2 hour job max.
Pep Boys has em for about $120. i did mine and it's still going great.
A good way to test when it won't start: have someone sit in the car. Get underneat the front of the car with a tire iron. Have them turn the key to start, and then hit the starter witht he tire iron (a forward jab works best). If the car suddenly turns over like nothing was wrong, it's ur starter. (i had to do that for about two weeks before i could replace mine)
