I did the Foglamp mod today.
HotBoxSHO
Portland, Maine
As the post says I did this following the directions on shotimes. It's very easy to do in under 10 minutes and I'd definatly recomend it.
It lets me run my fog lamps with just the parking lights on, and with the highbeams on.
'93 SHO ATX. Inner airbox removed, 15% tint, Fishtank and foglamp mods, Alpine head unit.
T
ThatSHOkid
Guest
how do u do this mod? and also where do u get the parts to do it?
J
Jeremy Hohn
Guest
If the switch was like mine, all you have to do is splice two wires together like they say in shotimes. No parts necessary except some minor wiring tools. Just follow the instrucions. Quick and easy.
Jeremy
1993 atx 126k miles
ENGINE:
-SHOSHOP underdrive pulleys
-SHOSHOP cold air induction
-SHOSHOP 80mm MAF
-Ted Breaux LPM
-Performance Plus y-pipe
-SHOSHOP catback exhaust with Magnaflow chrome tips
-Redline Water Wetter
-fresh 60k (SDPATT)
TRANNY:
-Rebuilt 94/95 axod tranny with trans-go kit and Redline Type 3 ATX fluid
BRAKES:
KVR cadmium plated and cross drilled rotors with performance friction pads
APPEARANCE:
-Colgan hood cover with SHO lettering
-Lund blackouts front and back
-Cincysho white face gauges
-black body filled s-h-o lettering
-Blazer fog lights
-PIAA high output headlamp bulbs (fratperformance.com)
-fish-tank bulbs installed
-wclewis "powered by yamaha" black badges
HotBoxSHO
Portland, Maine
Thats right Jeremy, it's very easy and requires no parts. All you need is a wire stripper/cutter, and then follow the directions on shotimes.
'93 SHO ATX. 115k. Inner airbox removed, 15% tint, Fishtank and foglamp mods, Alpine head unit.
HotBoxSHO
Portland, Maine
Here are the directions from Shotimes:
FUNCTION OF MODIFICATION
To allow the fog lights to function with only the parking lights on, but also leaving the fog lamps hooked up to the autolamp (automatic turn on/off feature), and parking lights on, warning chime.
Note the fog lamps will not self turn off when high beams are turned on?This may not be legal in some states.
ORIGINAL TOP TO BOTTOM ORDER OF WIRES CONNECTED TO FOG LAMP SWITCH
1. BLUE/ RED STRIPE
2. BLACK
3. RED/ BLACK STRIPE
4. YELLOW
5. EMPTY
FUNCTION OF WIRES
1. POWER FROM PARKING/DASH LIGHTS
2. GROUND
3. POWER FROM HEAD LAMPS
4. POWER TO FOG LAMPS
5. EMPTY
MODIFICATION MADE TO FOG LAMP SWITCH
1. Remove the fog lamp button on the dash, using a thin flat screwdriver or butter knife. Note the wires connected to the back, they should correspond to the original list of colors and functions above.
2. Cut the 3rd wire from the top (power from head lamps), leaving about 2 inches from the back of the fog light switch. The cut wire coming from inside the dash (power from head lamps) should be taped, covered, or capped some how, as not to allow the metal tip to touch any thing causing a short. This wire becomes live when the head lamps are on.
3. Now cut the 1st wire (power from the parking/dash lamps) again leaving about 2 inches from the back of the fog light switch. Be careful the wire coming from inside the dash is live when the parking/dash lights are on, so keep the lights off and/or cover it temporarily once cut.
4. The cut 1st and 3rd wire attached to the fog light switch need to be stripped about ½ an inch from the cut tip.
5. Now the 1st. wire coming from inside the dash (power from parking/dash lamps) needs to be stripped and spliced to attach to the 1st wire still attached to the fog light button and also to the 3rd wire still attached to the fog light button (originally power from head lamps).
6. Once the 3 wires are spliced together, tape them up or cap them, and check for proper operation. Check all combination of parking lamps, fog lamps, head lamps, and high beams.
7. If everything checks out and works properly just pop the fog lamp switch back into the dash and enjoy.
***Note the only tape that should be used is insulated electrical tape.***
SHO SPD
SHO member #480
Naples, Florida
NOTE: Thats not for the 89 SHO, the 89 has a different wiring setting, I did it to mine, but I had to figure out what wire did what, but still looks good.
Matt
1989 Titanium
ITS FOR SALE!!!!!
e-mail me for details, would like to sell SOON.
SHO SPD
SHO member #480
Naples, Florida
Its just a cool look when its dusk, theres enough light to run with no lights, and dark enough to run with your parking lights, I dont know, its just a fettish to me, I like the looks of cars running with their parking lights, and or with fogs and parking lights. Then when its just dark then run with your headlights, but you have to keep your fogs on no matter if it is a clear night.
Matt
1989 Titanium
ITS FOR SALE!!!!!
93SHO
Littleton, CO
I just got done with this mod a few minutes ago. It took me a while because my idiot friend who was supposed to help me started snipping wires when I was making a snack run... so yeah, it took me about an hour. He basically skimmed over the directions and started making guesses. Frickin idiot.
1993 MTX.
Mods - Quaife, Baer brakes, 2" dual exhaust, Dynomax mufflers, H brace, Koni struts, front camber/caster plates, rear control arms, SHO shop springs, solid aluminum radiator, big bore butterflies, cold air, K&N, kevlar clutch, high flow cats, 80mm MAF, front and rear strut tower braces, 16" ROH Sniper wheels, BFGoodrich KDWS 225/16/50 ZR4 tires, and LPM
Sitting in basement - Garrett turbo BURNOUT (who knows...)
T
Tommy the Greek
Guest
Yes, it is an excellent mod. As far as the fish tanks, I want to put yellow LED lights in mine. I have the 194na bulbs in them now.
