FriedRiceBob
ok, I went out and hunted around by braile for about 20 minutes without 'feeling' anything that i could think is the VSS. car is '93 ATX
i did find a cylindrically shaped object with a plastic type heat shield in the general vicinity of where i've gathered that the VSS is supposed to be.
so here's a pic, help me find it please.
the front of engine bay arrow should help orient you. so should that heat sheild which is on (i think) the exhaust manifold. you can also see what is a cylindrical canister attatched to the firewall.
so, SHO gurus, point me in the right direction...it started raining so i had to hoof it back inside, but i'm gonna go back out later and get this changed out.
