MailManMike
ok, i have an 89 sho and was fed up with the stupid cable shifter so i found a really good deal on a rod shifter and took advantage($50). I disasembled the cable sh*t and cut the cables and hung up the rod shifter to see that the "well" that the bolt on the stabalizer bar screws in to is cracked in half ! half of it is completelty gone. i cant put the cables back on b/c i cut them . i was thinking about cutting the stabalizer bar and rerouting it to a different hole on the tranny and then welding it because i cant weld it to the tranny (aluminum & steel dont mix
) so anyways my sho lay dead outside for the time being unable to be shifted . is there anything that can be done ? -thanks
