Hub/knuckle question-do i have upgrades already?
CheckerSHO
Ford Employee
Acworth, GA
I went to put some good rotors off of my 90 parts car on my 93...and they wouldnt fit over the hub :confused: i thought 89-93 were supossed to be interchangable, but the rotor would not fit over the center of the hub. Does this sound like i may have 94-95 knuckles on my 93 already? This car had a LOT of modfications on it when i got it...so it wouldnt be too suprising :D
TIA
pjtoledo
'ol man in the SHO
toledo,ohio,usa
As stated, the center hole is bigger on the 93 hubs. About identifying a possible upgrade,,stock 89 thur 93 front knuckles have large "tabs" that physically prevent larger rotors. Those calipers are attached with Torx bolts. The 94/95 knuckles have 2 regular bolts that attach the caliper to a bracket, and 2 more bolts that attach the bracket to the caliper. The 89 thru 93 rotors are about 10",,the 94/95 are 11" rotors. If it's aftermarket stuff, I don't know.
Perry
CheckerSHO
Ford Employee
Acworth, GA
Thanks! looks like i just have the stock hubs :( when the rotors wouldnt fit, i thought i was onto something but the lack of a separate caliper bracket means i definetly do not have 94/95 stuff. oh
pjtoledo:
Perry
SonicRiot
Handbanana!
CT
89 through feb. of 91 are interchangeable. The hubs were switched for the rest of 91 and were used until 94 (I think...or was it 95?)
ribeye2065
