Front Spindle/Knuckle
bluemoney
ca
I have 2 90 MTX SHO's and a 94 ATX. I have a left from spindle/knuckle that is worn real bad were the brake pads sit it has 355,000 miles. Does anyone know if all the parks from the 94 will fit on the 90, like the knuckle, strut, caliper, rotor and pads. Thanks Much Larry
Irish Pride
Irish Inside
MusicCityUSA
94 and 90 are completely different. 94 uses a caliper and bracket setup where as the 90 caliper bolts directly to the knuckle.
That being said, you can swap the 94s to the 90 no problem as long as you swap the brakes too. Everything else will mount up the same. You can also do the 96 bigger brake upgrade if you want but keep in mind that it does require at least 16" wheels to clear.
-Chad
bluemoney
ca
-Chad
Thank you very much I think I'll take everything from the 94 and put on the 90 that way the pads won't wear the knuckle out. I'll start using the 94 for a parts car. I have 17" on all 3 SHO's.
sperold
Last to Know
Another bonus for the swap from 94 into the 90 is, you do not need to press out (and in) the wheel bearing on the 94 hub.
