ShoGuy93
Yes I Have Blue Rims
Ok while i was trying to get the beater running i thought i would switch coil packs. Well i have a spare pack sitting around off of my project motor. Well i go to put it on and the coil plug in is different. On both the silver bullet and the beater. On the coil pack plug in, there is a plastic peice on the plug in (On the bottom) and it is to the left. Well this coil pack from the other motor it is straight up and down. So i was like o ****! Did i get a wrong motor. So i went threw and checked some stuff. The alt that came off of the project motor is a 120v. And thats what atx's had on it. I checked the valve cover marking and it was kob which i did a search and some people said when it is a kob it is a 3.2. KOA's were 3.0L. But i can't go by that cause valve covers are switched all the time. And the intake manfold all the egr stuff is there. But that could be for a CAL car. So I'm worried that i have a 3.0L here and not a 3.2L. Or is there a difference in the coil packs and the coil pack wirning harness? (if u get what im saying) Is there really a way to check besides seeing what the bore is on the engine? Please respond ASAP i'm freaking out here!!
