How To Repair Missing Speaker Connectors
mrecoolgar
SHO NUP
Hershey-PA
Instead of using an adapter that costs $, the previous owner elected to cut off the original Ford speaker connector.
I had the cut connectors, but if you do not then a trip to the salvage yard is needed.
Some may decide to solder the wires together, but I am using original Ford crimp terminals.
They crimp at the wire and a second crimp in the insulation to act a a strain relief.
Then slide the repaired ends into the factory plastic connector.
Just as factory intended, albeit a bit shorter.
SHO1
Coke Is It!
The State Of Hockey
Are those terminals easily and/or still available? Are they a Ford parts only item or can they be has elsewhere? Txs
Nomospm
