How Much Do I Tourque down a Lower Idler Pulley
Lower Accessory Drive Idler Pulley Bolt (3.2L Only) 36-55 n-M 27-41 lb-ft
<small>[ July 09, 2003, 01:49 PM: Message edited by: projectSHO89 ]</small>
rangerj
Brunswick, Ohio
Aaron,
Consider replacing the nut with a lock nut. Torque it to about the middle of the range.
This would be a good time to remove the pulley mount, clean the threads on the jack screw, and put some anti-sieze compound on the jack screw. It makes adjusting the tensioner a lot easier. rangerj
