SHOZ123 said:15-18" and steady when idling and warm. Get it directly off the manifold.
On the intake after the TB.plethaus said:I would like to test this on my own car, where do you hook up the gauge to test?
yamahaSHO said:On the intake after the TB.
SonicRiot said:At idle, the car should be pulling about 18 in-hg of vacuum. If it's significantly more vacuum, you may have valvetrain issues such as sticking valves.
SonicRiot said:You are testing manifold vacuum after the throttle body to give yourself a window into the condition of the engine. At idle, the car should be pulling about 18 in-hg of vacuum. If it's significantly more vacuum, you may have valvetrain issues such as sticking valves. If you have significantly less vacuum at idle, you most likely have some power issues related to anything from vacuum leaks to bad rings or even timing issues.
If the car passes a vacuum test at idle but still has misfire or driveability issues otherwise, you may have just narrowed down your search for troubles.
A vacuum test at idle is a simple way to determine the basic condition of the engine without going into compression or leakdown tests which often take a little more eqipment and time.
Does that help plethaus?
yamahaSHO said:Whenever you open the throttle, you're going to lose vacuum. WOT should indicate atomoshpheric pressure (or zero) on an NA motor. When you let off the throttle, the motor is spinning faster so you'll read more vacuum until it settles down to idle speed.
