A resistor will not do the job. You need a transformer.
Fortunately, every cellphone in the market currently runs on... 5 volts. You know what that means; any car cellphone charger will work. You will want to get an extra cigarrette outlet from AAP or AZ (they all carry them) and wire it into a switched or hot power source of your choosing. Then, simply insert the cellphone charger (the smaller the better, obviously), wrap it with tape of your choice to ensure it doesn't slip out (they generally don't), and cut the end of the charger to either directly splice wires or attach correct connector as desired. This will give you regulated, fused 5v.
There are also a couple of regulated 5v lines off the EEC if you want to go that route.
