Hood Question
XtremeSHOCreations
Coldwater,Ohio
can a sable hood work on a sho?
what years of taurus hood's work on a sho
bc im thinking bout getting a used hood for my sho so that i can make my custom own cowl hood at school
and yes im in a auto body class
ACV1081
Member #187
IA US
He's talking about the structual bracing on the underside of the sable hood is not designed the same as an SHO hood and comes closer & maybe even rubs the intake. Not exactly ideal, but if you're modding it and making a cowl, then perhaps you can conquer that problem at the same time. Question is why use a steel hood? If you can afford it I'd go fiberglass from cincySHO or something and lose a whole lot of weight. If you're on a budget then I commend the self-fabricated cowl. Hope this clears things up.
R
rockfordsho?
Guest
your sig is longer than this thread.shorten it.
try looking through the junkyards shouldnt be too hard to find a cheap sho hood.
ACV1081
Member #187
IA US
rockfordsho?:
Hey smartass why don't you vote... VOTE I post my sig to help answer questions not to take up space. Matter of fact unless a moderator tells me to shorten it, I'll modify it however I please :p
<small>[ December 10, 2002, 11:26 PM: Message edited by: ACV1081 ]</small>
Mr Anonymous
Tire Wall
rockfordsho?:
Have you ever actually made a post to the forum that has contributed in any way? You seem to spend a lot of time criticizing others, and now you seem to think you're a moderator. I know the real moderators have deleted a number of your other posts, perhaps it's time to find someplace else to spout your misery.
XtremeSHOCreations, a Sable hood will mount up correctly and look the same as a SHO hood, but the problem as has been mentioned is that one of the braces on the underside will lie almost directly on top of the DIS module on the intake. One slam of the hood could shatter the DIS. It's probably not too hard to modify the bracing to sufficiently clear the DIS, and if you're going to work on the hood at school to add a cowl, then you can probably pretty safely use a Sable hood as long as you ensure good clearance. Good luck! :)
nothingtoseehere
rockfordsho?:
your posts bore me,stab yourself.
Dude, go away. It is obvious no one here cares to see you around, do us a favor and **** yourself. Adam has been a contributing member of this board for a long time....damn n00bs I wish they would start watching who they made enemies with.
ChitownA34DR
American
Oak Lawn, IL
Actually Robby, Mr. Rockford has been around a long time and has pretty nice Gen III nitrous powered SHO, but yes he is a dick. thumbs_u
<small>[ December 12, 2002, 11:59 PM: Message edited by: SmOkE93SHO ]</small>
SHODWN
Mother Threasa
Spencer,Ma usa
Well your all right and wrong.
A Sable hood is the SAME exact hood. What they do is cut a brace out for the SHO. A slo hood is made for the Taurus which has fifferent fenders (sable) custom bumper cover( thanks again Sable) and the head lights and mounting panel are once again taken from a (sable)
jthomas68
Area 51
rockfordsho?:
You `ve had more than enough chances,but continue to act the same.You`re gone...again,don`t expect to be here much longer.
Edit:bye bye boink
<small>[ December 13, 2002, 11:22 AM: Message edited by: jthomas68 ]</small>
Yamaha V6
SHO Enthusiast
Rhode Island
FYI, I believe Eric S's (SHOTime) white 94 had a SLO hood on it, not a sable hood. It was recessed down into the bay, not flat.
FYI. I didn't take too close of a look at it before the car was parted, sorry.
jthomas68
Area 51
Fred,you are probably correct,it depends on which Gen is in question.The way it`s been told,a Sable hood fits the Gen I and the SLO hood fits the Gen II,bracing not taken into account.
<small>[ December 13, 2002, 01:52 PM: Message edited by: jthomas68 ]</small>
SHOMA
Springfield, MA
From first hand experience, I can say at least that a Gen II taurus hood, 95 I believe, will fit a 94 atx with no rubbing or anything.. The guy wanted the newer style SE hood, with the hood lines in it, and he mounted it/painted it, no problems whatsoever... SO.. Good Luck, but all I can say is that it did work when he did it!
Kevin
pjtoledo
'ol man in the SHO
toledo,ohio,usa
95silvermtx:
Kevin
Does anybody take into consideration the different engine locations in MTX vs ATX? Just a curious thought. Anybody know the actual weight difference between steel and fiberglass hoods?
Perry Toledo,Ohio
rendyx
Buffalo, NY
Here's any interesting thing on hoods. My hood's only obvious feature is the bulge going straight down the center. Now, I parked next to another 89 (I also have an 89) a while ago, and its hood had 2 bulges, each going to a side of the grill (like a sort of mini-cowl hood). What's up with this? Who has what hood?
