hood dosent want to close?
white91sho
painesville, ohio
i got a 91 sho with the plus fiberglass hood, whenever i go to close my hood i have to slam it so hard im afraid im going to break it. anybody else have the same problem or heard of this problem before? can anybody help me fix this problem? thanks.
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
replace your hood latch (hindge) or spray some WD40 over that , that happens due to grease and dust mixed toegther, and is like a glue which wont allow your hood to grab the hindge
good luck
endri
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Try a dry film lubricant with Teflon or some of that other fancy stuff in it, PTFE or whatever. Once the WD40 dries, it will be the same 'ol sticky latch again. And adjust your hood stops.
Perry
1stSHO
Asian Lover
Fort Walton Beach,FL
Tell your hood you will replace it with a steel hood and send the fiberglass on to me and ill even pay the shipping!!! :biggrin:
TREpaNaTion
Local Metal SHO
Minnesota
Could always Put some hood pins in it to keep her shut :bonk:
but nah i would say some good ol lubricant as they said would take care of it :) I have the same problem with my winter beater (94 buick regal)
white91sho
painesville, ohio
i went and baught some JB blaster ****, i soaked the hinge with it and it helped a little bit, but its still a pain to close. i might try and go find a new hood latch and see if that helps.
F-22 Raptor SHO
7015 feet above Sea Level
Use more. I would seriously do the spray the **** out of it (latch and the catch, and the cable with wd 40. Night and day difference with my car. I was having to slam the hood with 2 hands like I was having a fight with an ex girlfriend in order to close it. Now after wD magic, I can close it with 1 finger.
etc1006
Baltimore, Md.
Have you tweaked the latch with all the slamming? Check the alignment. also if you do decide to replace the latch, grind the nubs off the back or else you wont have any alignment. The nubs go into 2 holes in the core support and thats it. I had to grind them off to align my hood after the core support pull.
